I was trying to log into the laser cutting computer, and I got this error.
Is it because I haven’t been added to the authorized user list yet? I got trained while helping cut out the makerspace logos for the front display tables in the lobby.
Check Maker Manager 4 and see if you see “Metal Shop Dynatorch CNC”. A side note, to not use Maker Manager 4 to do anything else.
I don’t see it listed on the right.
I would wager you’d need that AD group to log into that computer.
So – did Randy @rlisbona check you off on the Dynatorch? He should be the one adding you to the Active Directory.
I thought I added Adam last weekend, I must not have hit the apply button because the other user I added at the same time worked
Sorry about that @philmcjoe
