I have some 2D flat pattern files in dxf format that I need burned on the plasma cutter. It will be cut out of quarter inch aluminum plate which I will provide. All I will need from the right person is their knowledge of how to work the machine. It shouldn’t take more than an hour to run the entire sheet. Should be pretty simple for someone you know has basic plasma cutter knowledge. Please call me at 817-313-7923 to fulfill this job. Thank you
