Does anyone have successful experience plasma cutting diamond or tread plate aluminum or steel on the dynatorch? I’d like to know if I can cut it with the pattern side up so the slag goes out the back if at all possible even though the height to the torch varies as it goes over the pattern.
the auto-height control can sometimes track it, but I’d still recommend cutting it downward and just expecting to do cleanup.
No matter how you cut, expect to do cleanup.
