The parts washer is past due for having the fluid / detergent renewed (not just topped off) and the filter/ sock is blocked.
I’ve still yet to be given information on where the fluid is supposed to go should you not be around to pick it up.
I think there are more filters in the committee cabinet
If you put the old fluid in 5 gallon buckets with lids on securely, I will pick them up.
The rubber gloves that are on top of the left green tall tool locker is what I used to clean out the drum with.
P.S. Jim, do you have a pattern for replacement windows for the vapor hone window? if so, I can get my local glass vendor to make some out of tempered glass - I noticed it is getting pitted. It is not beyond serviceable yet, just being proactive.
We don’t have a template AFAIK, but we do have a spare we can use to make one. It’s not the first time we’ve replaced it either. They seem to currently last about a year before they’re completely unusable at all, but definitely a notable impediment well before then
