Does the “Space” have any 4-Way panel clamps such as Damstrom’s or WoodRiver #125392W?
If the “Space” does not have, would any of our woodworking members have that I may be able to use for an overnight glue-up?
We have many parallel and pipe clamps which are both commonly used for panel glue ups. F-clamps and clamping cauls can then be used to keep boards aligned in Z direction, a la:
Review this link for additional discussion:
We should have several of these.
http://www.rockler.com/4-way-equal-pressure-clamp
I made some of the horizontal notched things a while back but no idea if they are still around.
I was thinking of those as well, but can’t remember the last time I saw all the parts together in one place. If they are going to be anywhere at this point, i’d guess they’d be in the quagmire on the bottom shelf area out in the woodshop annex by woodworking work table…right? ![]()
If you decide to make some clamping cauls, you can use my Parameterized Star Knobs on Thingiverse to 3D print the tightening knobs.
I need something like this for 10mm bolts. I am making a bunch of jigs to mount to the slider on my new tablesaw. I might try to print a few out and drill them to fit! I do realize you would probably resize but that would take more learning than I hope to do since I have never done anything but download and print.
Thanks for posting
The knobs are fully parametric: if you load the file on a machine with OpenSCAD (free download) you can set the bolt diameter (and most other dimensions) in the code and then generate a new STL from it. It’s pretty well documented, but if you want, I can help set up some knobs to meet your needs.
I will be at DMS all afternoon/evening on Friday - if you want some help, come find me.
The 4 way clamps are on the shelf by all the other clamps. They are in their original boxes on the top shelf.
LOL, original box. I almost spit out my water.
