Hi David (@commandhat)…
Thanks for the input! All info we can receive will help us narrow down what’s going on.
It seems to be pretty much the very same thing that would happen with Pronterface - just with different error messages. Back then, when “something” would cause a hiccup/disconnection, there would be no way to do anything with the printer - until after Pronterface was closed and the printer was reset (using the red reset button inside the printer). With Pronterface, there were no obvious “error messages” - because the application would just freeze up (so there could have been an error message trying to display; but, since the app would become totally unresponsive, there would have been no way to know for sure…). Again, when that would happen, Pronterface would have to be closed and the printer reset, then things would be OK again for a while.
NOW - instead of the app totally freezing up like it would with Pronterface, we get actual error messages (the connection, time out, not authorized, etc… errors are all variations of the same thing - just pop up with different wording - depending upon what you are doing at the time).
As with Pronterface freezing up, the error messages we see in OctoPrint will often eventually clear themselves - after several minutes or more; but, not always. If you don’t want to wait so long (and who does?
), then what “usually” works is pressing the red reset button inside the printer, waiting a couple/few minutes, then refreshing the browser and trying to reconnect. Every once in a while the printer will continue to not respond; and, when that happens, you may have to reach around to the back of the printer to press the power switch (toggle button next to the power cable) to power cycle the printer. Please only do that as a last resort, as I have seen the USB cables get knocked loose - from the back of the printers and from the Banana Pi devices - which cause additional issues, as you can imagine.
Oh and don’t forget to send detailed reports to [email protected] any time you have any break/fix type problems! There is also a log book to log the issue, as well as sheets of paper that should be taped to the printer, if it’s something that will cause others not to be able to use the printer (such as if something gets broken and the printer is truly out of service, etc…).
Thankfully we have a pretty awesome support group - including PolyPrinter (@edkman) who is working with us to ensure there are no compatibility issues within the firmware, etc… [I can’t say enough good things about how well PolyPrinter goes above and beyond to provide top notch support!].
Thanks again for the feedback!
Lisa
