Its something we would have to look closer at to see exactly where the noise is coming from. The spindle bearings aren’t too bad or expensive. It maybe the CV pulley/belt making the noise too
Took some time to wrangle all the materials together.
On the cart we have 12 gallons of Mobil DTE 24 ultra (about a half gallon of regular 24 DTE), o-rings for the colchester, Shark compound bolt, capacitor for the dust collector & gloves.
The tasks that were completed
Bridgeport quill power feed speed selector, Bridgeport Quill return spring.
Shark Lathe; oil change, compound cleaned up/smoothed up action
Colchester, well a little less successful on it. We need to put the compound back together, replace the o-ring for the shifter, finish changing the oil
Sherline mill has light mounted over them now.
The wall/safety partition completed for Machine Shop
Some straitening up of the teachers cabinet
Plastics needs a replacement run cap, not start cap as initially thought.
Plastics equipment is now linked to the Wiki.
Not that thats “IT” that was done, but there was a lot of progress today. Again thank you all.
