Final discussion and vote regarding selling the Lincoln TIG unit
Vote on switching to an exterior welding gas system at an estimated up front cost not to exceed $2000, followed by swapping in increments of 6 bottles in a cradle pack
Discuss any new business & requests
Must Do Chores List
Check our current assortment of safety glasses (both shaded and clear)
finish welding small cage for pony bottles to get them out of committee storage.
check grinder wheels
check welder wire and gas
check vapor hone water & media
general sweeping and cleaning of shop
sorting of the committee raw materials
removal of personal property found in various corners (stashed material, projects that are not permitted for storage, etc). Will coordinate with Logistics on whether we can stick these in Purgatory or what else will happen
Other items for todo list
Cut down old plasma slats for MIG classes
if Lincoln sale approved:
** do a sample weld and photograph
** takedown unit, photograph parts and kit
** bundle cables etc neatly for temp storage
** use space generated to make the PPE storage a bit neater in the interim
Items for Acquisition on Supply Runs
Vapor Hone media, if needed (Aluminium Oxide, by the Bucket)
I will be running by the metal store to grab 4ft sections of mild steel for TiG classes and to replenish the emergency stock on Monday/Tuesday.
More than happy to help weld up the pony bottle containers. Not 100% sure I’ll be able to make the meeting yet, depends on if I can get a return flight before then or not.
We have plenty of aluminum - I only cut 2 of them last class, put the remainder in the emergency stock. I’ll check tomorrow.
Did not see any steel, but haven’t checked since the class. Will look tomorrow when I’m up and get you an accurate number. We have plenty of the plasma table slats (new) but not so good for TiG welding unless we want to burn new slats.
Once again I’m out of town. Convenient eh? Seriously, I hate miss these meetings. Also once again Charlie P. Is authorized to do any cleanup assigned to me. LOL
Just picked up 40ft of 3/16x2" Mild steel flat. Will drop by the space and cut it later tonight. I will put one classes worth in the teaching cabinet pre-cut.
Tails Hartnett
nicole fontenot
JJ Perry
Ron Flores
Tim Bene
Marcel McClain
Charles Procter
Votes:
Proceed with External Gas project, not to exceed $2000 (note: focus on attempting argon only since MIG will run with Argon, but have budget for mix gas as well). Will proceed regardless of Board allocation. - Unanimous
Sell the Lincoln TIG - Unanimous
Tasks completed:
sorted and culled the committee steel rack
removed all illicit personal storage and abandoned items
heavy cleaning
disassembled the Lincoln TIG. It’s currently in 102 with other hardware that is available for sale. On pallet and readily moved @apparently_weird has offered to take some better photos of it and its parts
removed the old tungsten grinder
laminated instruction manual for new pencil-sharpener style tungsten grinder
Fixed vapor hone, nozzle was clogged.
Replaced the gloves on the vapor hone.
Charles cleaned the window washer nozzles.
Charles Shortened the weir in the basin.
Charles checked the ground for the dynatorch. We have .83 volts between the ground and neutral.
I charged the grounding rods with salt water.
