So I started a print on my printer using OctoPi. Later when I came home, this is what I saw (attached). The printer was printing along if if nothing was wrong - except filament wasn’t being extruded.
The filament had broken (or got chewed up) by the dual-gear extruder.
The Boudin Tube appears to have filament in it which makes sense.
The extruder gears were both turning properly, so I don’t think it is a slipping extruder gear.
My questions: What caused the failure? What steps should I take to diagnose the situation?
My thoughts are: 1) Turn on the heat, make sure the nozzle is heating properly.
2) Disconnect Boudin Tube and remove remnant. Insert new filament and see if printer works.
Is there anything else I should do before Step 1 and before Step 2?
Thanks in advance for your help.
