6 foot long. what the heck would you use that on? I don’t think it’s 0.001" accurate though.
That can not possibly be useful…
Just the weight alone.
You think that is bad, what about the 6 foot micrometer? You have to measure the crankshaft journals on cruise ship Diesel engines somehow.
Yes, they are that accurate. But they are getting large enough that temperature compensation may be needed. Largest set I’ve ever helped use were 72" . Used them in large diameter pipe weldments to get both pieces round enough to weld.
I’ve seen & was part of using 6ft micrometers. It was for a compressor, we suspected the diffuser plate guides were not deep enough. We suspected correctly. We did let them acclimate to the ambient temp in the plant. (At UTA)
Just curious: by how much were they off?
We used to use large ones like that when I was making refractory blocks for glass furnaces… had to be within 2/1000 over a 4 ft length or bad things could happen… imagine a couple of tons of hot glass spilling out of a furnace.
Last I heard, they finally switched to laser based measurements on the really critical stuff though.
I used to perform electrical and control repairs on a 16 foot vertical boring mill, before retiring last year. They used this size (and larger) to check the I.D. and O.D. on the items they turned on this mill.
