Nichrome is standard bead rack rod material and having a local cheap source for it is great to know. We’ll keep Tanner’s in mind.
It will survive well beyond our glaze temperature, but it’s really rated to be used below it. I’ve seen max operating temperatures ranging from 1650 to 2100. Nichrome turns green or sometimes black when fired. This makes it resistant to oxidation at high temperatures but can leave stains. It also off gasses chromium which can react with glaze.
Lots of folks use nichrome rod with no issues, don’t mind the off gassing or the staining. Others cover the stains with enamel paint or some other way. Nichrome is a good way to go in those cases as it cheaper.
If the nichrome properties aren’t acceptable, Kanthal A1 is the go to alternative. Amazon has 25’ of 18 gauge for $7, enough for plenty of rods. That’s the thickest they seem to carry. The local vape or hobby shops may carry thicker wire. I think the 18 will work fine though.
Anyone using the FA bead racks don’t need to supply nichrome rods unless a smaller diameter is needed.
