I saw this Burr King 2.5x60 belt grinder on an auction site, placed a low bid, and accidentally won it. Looks like it was hardly used. It is being rewired for 208-230, has a built in dust collector. It will be on indefinite loan to the Metal shop. We already had a power drop waiting for it.
Please don’t abuse it. When using any belt or bench grinder use light pressure and ALWAYS keep the part moving across the face of the belt or wheel. Someone recently destroyed our huge sanding disk and a scotchbrite belt by pressing too hard and not moving the part so it cut a groove in the abrasive.
Since the belts are super easy to change out on the Burr King vs our other horizontal belt grinder and glue on disk sander we are going to try providing a course belt, if the belts get damaged before they are worn out we’ll need to go to “Bring your own belt”
Someone needs to make a sign with this instruction (and similar ones about sleeves, rings, jewelry getting caught; etc.) and tape/glue it to the front of the machine – under the top “Burr King” sign. I volunteer . . .
People who do not read signs usually get laughed out of court. So it’s still worth having. It can make the difference between victory and an expensive settlement.
It’s not too bad, you can put it in a flower put and suspend the pot over a bucket of sand. Light it with a strip of magnesium, run away, and watch molten iron drip down into the sand.
