You can now sort classes by 4 different variations! Explore them at calendar.dallasmakerspace.org on the right.
This is sorted by “Created most recently”
You can also see the cost for a class at a glance!
This is great! Thanks!
Did one of the recent changes accidentally get rid of the “FULL” indicator on the class list?
Maybe?
Any way to filter out classes that are tagged as full?
This is what I see on the Events page:
EDIT: Looks like it works on https://calendar.dallasmakerspace.org, but not on https://dallasmakerspace.org/calendar.
What browser are you using? Possible incompatibility?
I’m using Chrome, but it appears to operate different depending on the way you get to it.
I can confirm that as well.
The embedded page is different HTML. I recommend we remove that embedded page and just link to the calendar
that is a nice feature add.
I’m trying to schedule the Purple room for two classes. I can’t tell when it is being utilized. Thanks, Jeff.
As far as I can tell, you have to pick your preferred date/time, and give it a whirl. Obviously, you can check the calendar for events already scheduled/approved. If there’s a pending event for that resource, it will reject your request, and you’ll have to try it again. I am not aware of a way around this.
This seems like a good enhancement to request, but I don’t quite know what to ask for. Could request to see pending events (at least, the schedule and room, even if the other info is limited). Could request that rooms get “greyed out” based on time/date when entered… I guess the request could be: way to know if room is available without having to fully submit and await rejection.
Hmm. Open to suggestions, if we’re going to formally make this an enhancement request. (I don’t see anything meeting this description in the existing list).
An exception: You can check the calendar but if the room is reserved and in the 48/72 hour review period it won’t show up but classroom is reserved until rejected.
SO if you don’t see a class using the room but it shows reserved, it is probably in the queue.
Thanks. I might just have the class at my house. It would be easier and I have three lathes and video. And Internet. Yahoo
Is there a room we can use video other than the Purple room? It would only be for 30 minutes and 8 people?
Any classroom that is free/not scheduled for use with a monitor or projector is available for use on a first come first served bias.
Pretty much all the classrooms have displays, except the Conference room, where we use one of the free range monitors off the shelf in the Common Room.
The monitor in Purple will go to the cart in Conference Room. Then one of the two old monitors in Interactive will go to Purple - so it has a bigger monitor.
Just needs to be moved.
