The new-old Metal Shop oven was wired in tonight, and tested. It is functional, but before general use it needs some tweaking. The previous users added an additional controller that set a hard temp cap of 250F (this was for their specific process, not a general safety feature) and this has to be bypassed; once we determine the ideal maximum temperature the unit should run at it will be reprogrammed for that purpose.
Things to note:
- It will require basic training, similar to the cold-cut saw in the Machine Shop the power will be locked out with a padlock and can be spot trained.
- Like the old oven loaned by @dallasmagna, this currently shares the 3 phase outlet with the Induction Heater; only one can run at a time. When the expansion hits we will look at fixing this scenario.
- The PID controller manual will be made available on the committee drive, along with some simplified instructions for common use, in the near future once we finalize any possible controller/operational changes
- This oven is big. You can fit a truck bumper in it (I know the first thing I’m powder coating is mine).
If you have any questions, post here or ask someone from @Team_Metal_Shop
If you have something you can use the oven for this week, let me know if you are willing to have it be a test case.
Cheers,
-Jim
