Each laser has been equipped with a “light switch” toggle to power on/off the blower (and soon the cooler).
In order for either laser to work, the switch MUST be “on” for the laser you are using!
If it’s not “on”, the laser may appear to be working (it may move; but, it will NOT fire the laser).
Even if the blower is already switched “on” for the ‘other’ laser, it MUST be “on” for the laser you are going to use.
More details?
- There is only one blower.
- Each switch can power on/off the blower.
- Each laser must have the blower (and soon the cooler) powered “ON” by the “light switch” for the appropriate laser.
- If someone is already using one laser and the blower is ‘on’ for that laser, you still MUST power ‘on’ the switch for the laser you will be using (otherwise, when the other person stops using the blower, your laser will no longer run…).
- Don’t forget to turn the ‘switch’ “OFF” for the laser you are using - when you are done using it.
I have been advised pix will be posted tomorrow to show exactly where the new “light switch” power toggle buttons will be located.
- If you have QUESTIONS about this process, please post in this thread.
- If you experience any ISSUES or Problems (with this process - or any other Laser Committee equipment), please send a detailed e-mail message to: [email protected]
Thanks!
