We have a new 50 ton air over hydraulic ready for use. The only rules are be safe (wear eye protection), ask someone first if you don’t know what you are doing, and post a picture of anything interesting you do with it.
Also you should not attempt to press pennies without using a hardened surface, I vastly overestimated how hard the steel is on the bolster plates that go across the bed when testing it up to its rated 50 tons of force
It did get flat, but it also pressed a penny shape into the steel
Some assembly pictures:
