This. With insulation I imagine you could probably make that into a workable really long forge. I think it’s gonna run a little cool, because there’s no room on this thing to mix O2 with your gas before it’s on fire. More air= more hotter. So forging temperatures may take time, but it’d probably get there.
Venturi’s are our friends:
And yeah, that sucker’s gonna drink fuel. Might have to go up to a big gas bottle to get around the supply limitations of the home-game BBQ bottles- at least if it had an air intake somewhere.
As to the stress issue, I’m just guessing from your pictures that the way this will make forging operations easier is that only the bevel will be at forging temp and that you can use the differential heat to move the metal away from the “cold zone”. Working the metal under this kind of differential heat is gonna cause a buildup of internal stress- might be fractures, might just cause warpage during heat treating, might be fine; but it’s introducing new variables into a process that doesn’t need them (at least for me). I have seen setups like this used for heat treat on swords and such that are too big to fit in the regular forge all at once, but the idea there is still to evenly heat the whole piece.
Never seen somebody heat during a planishing operation, might work for stuff that doesn’t need heat treatment, dunno, I’m definitely no armorer.
