Need to rent nitrogen tank…
I need to rent a nitrogen tank with regulator to purge my home a/c while I do some brazing.
Are there places that rent this stuff?
I have a nitrogen tank you can borrow but the regulator max is less than 100psi, if you are pressure testing you need a different regulator
I can let you borrow my regulator if you want to take it to test pressure. My regulator goes to 600 psi. However I think both of my nitrogen tanks are empty or low, I just haven’t traded them in yet since I changed my unit.
Thanks, guys! Tim, I’ll hit you up when I get a little closer. I need to get the old evaporator out and exchanged. Your regulator will be immensely helpful once the new one is in.
Randy I PMd you.
