I drive a Honda 2002 Accord SE 4 cylinder, currently has about 147k miles on it.
About a year a ago, I’ve noticed my car slip during shift change into 2nd gear. But this occurred only in the winter season or on really cold days.
About 4 weeks ago I’ve noticed my car clunked when I shifted from park to reverse. And clunked when I accelerated. I knew what the issue was, bad motor mounts but at the time I didn’t have the funds necessary for a mechanic to fix it. During this time my transmission slips during 2nd gear,
I’ve already spoke to a mechanic and he repaired the motor mounts and serviced my transmission ,just changing out the fluid. He noted the fluid was dark and didn’t see metal shavings or particulates in the fluid. He field tested the car and said my car slips during second gear but it not as bad as it used to be. He told me it’s possible if I come back 2 weeks from now to service the transmission, the slippage should be noticeably better.
Now that’s my background story.
My question, what can I do about this issue? Is my transmission going bad? Since I was driving under these conditions, did I damage the transmission somehow? Could something have gotten knocked loose?
I’m pretty stressed out, my mechanic is optimistic, but I’m expecting the worst.
Any thoughts?
