There is only one class for lathe 101 march 7 and it’s already full.
Is there any way I can sit in on this class still? Or when is the next class?
I’m not empowered to speak for the instructor, but you should know that participant cancellations are not uncommon. You can do three things:
Keep watching the calendar to see if someone cancels and a spot opens up.
Watch Talk. Sometimes if people have to cancel at the last minute they post on Talk so someone else can take their spot.
Show up to the class early (with appropriate attire and safety gear), with the understanding that if everyone shows up you are out of luck (it does, after all, require a lathe and there are only a fixed number of lathes). But if someone doesn’t show up you will most likely be able to take their spot.
Thank you for the advice, it helps.
