Nand flash reader for tSOP48 anyone?
I would like to dump a couple of nand chips but do not want to buy the programmer before I figure out if I can mae sense of the data.
One of the chips is pictured below. These are not from usb flash drives so I am doubting they have a fat file system.
Does anyone have a nand flash reader for this?
File not found.
I have a flash chip adapter for some chips. What’s the part # on the IC?
Can’t see that file, but if they have pins on two short sides and none on the long sides (rectangular), then I know what you’re talking about.
I don’t have a setup for one of those, so if Raymond’s setup doesn’t work out, this might be helpful:
Ok, so I mis-typed a bit of info.
It is a Spansion S29Gl064N90TF104 NOR Flash chip which I suppose can be read in a standard EEPROM reader with a TSOP48 adapter.
Datasheet
http://www.cypress.com/file/202426/download
Edit… This actually should be really simple with the arduino DUE.
