When using the MultiCam normally Z=0 is the work material top and a maximum cut depth is set to the wasteboard. In other words, cuts are relative to the top of the work material going down towards the wasteboard. This gives precise cut depths regardless of the work material thickness.
I’m about to cut a tongue (as in tongue-and-groove). So, instead of a precise cut depth I need the opposite: precise material remaining.
With the MultiCam, is there a way to work in the opposite direction? A way to set the wasteboard to Z=0?
I know how to do that in VCarve (Edit / Job Size and Position / Material Z). But that is not enough. The MultiCam has to also be told the work material bottom / wasteboard is Z=0.
