I just have the basic CNC class. Absent the impact on the environment, and the danger breathing the stuff, etc… Is it ok to use melamine on the multicam?
Yeah it’s fine. You might have to clean the bit when you’re done as the melamine might melt a little bit on the bit. There is an orange solution on the Woodshop cabinet for labeled blade and bit cleaner.
Please elaborate how would a user determine speed and feed for materials like this.
The melamine has either an MDF or particular board core. It is worked just like mdf. The question was more about permission than actually doable. The feed speeds should be consistent with the core material.
