New MultiCam Design Software *
Good news. @jast & @IanLee have finalized the paperwork needed to acquire VCarve version 11 for the Multicam. We can now begin working through the tool library and figure out what will be required in order to share tool settings with the authorized users.
The old workflow was for users to either:
- Sign-on via the jump server and use VCarve as a remote desktop application and design their job.
- Design their job in a CAD application of their choice and then goto step 1 above and import the DXF into VCarve for creating CAM tool paths.
The new workflow will not require using the jump server for design. Each user can download a full copy of VCarve for use on their personal computer. All design can now be done offline, while sitting beside a lake in the Swiss Alps that doesn’t have Internet reception. The workflow will continue untethered up until the point that the G-code needs to be saved. At this point the user will visit a designated DMS workstation where they will open the pre-created file and export the G-code for the job
We will be sharing a detailed workflow during the VCarve to MultiCam CAM class.
We are still waiting for the software and have not configured the new tool library, or figured out how we can share it with the user base.
Users who also use VCarve to drive other devices at DMS like PlasmaCam, Fusion Laser, Shapeoko, etc, will probably have a few more steps to follow.
On a different note, we are finalizing the design of the new dust boot and are optimistic it will provide a see through area for the cutter & hopefully float along the surface of the job. This could turn into to a working prototype with upgrades over time since we are trying to loc it down quickly.
If you have read this far, then here is the link for your free copy of VCarve. We will be providing an unlock license code in the following days. The key will lock your copy to the DMS CAM engine. You will be able to do everything except export G-code on your personal computer.
This software shows to be a evaluation version, but converts to an actual license when you provide the unlock code.
The download is roughly 1GB and is a Windows application. If you use a Mac then you need to follow your setup regarding running windows applications. Of course the software will be installed on graphics stations at the space for member use.
Note: You do not need to register at this point. There is a download as guest link at the very bottom of the dialog
https://www.vectric.com/free-trial/vcarve-pro
We will be publishing a list of tutorials for self starters in the near future and will also be providing classes on VCarve basics for those members who best learn in a class room setting.
