I’ve been meaning to post this for a while. @Axel_Ohmstede
This is an Adobe Illustrator file. The mounting hole in the file are meant for our RCBS single stage press. It is a snug fit and if you wanted to adjust the design I would increase the length of the vertical slots that mount the plate to the table for a bit more wiggle room. I cut the current plat on the CNC router with this file. Make sure to make insets for any bolt you use to mount items to the plate. I know it sounds like a duh, but I almost forgot when first designing it. The offset is the area in light blue.’
I also put a copy in the Hatchers Drive in the DMS Committee network drive.
