I temporarily installed temperature sensors on the Blitzen chiller lines. This is a proof of concept test. If successful, it may be expanded to a system with an LED display that also keeps up with usage and dollars to be paid,… Results can be seen on the following links:
5 minutes - https://thingspeak.com/apps/matlab_visualizations/218536
30 minutes - https://thingspeak.com/apps/matlab_visualizations/218508
6 hours - https://thingspeak.com/apps/matlab_visualizations/218518
24 hours - https://thingspeak.com/apps/matlab_visualizations/218521
You can see the microcontroller taped to the handle of the chiller unit. The sensors are taped to the lines. The one on the left with the dab of lime color is Sensor 1. It is connected to the “Outlet” port of the chiller. (Is that the outlet of laser or outlet of chiller?)
Results are interesting but a bit mysterious. Sensor 2 tends to lead in time but is generally half a degree F cooler. Specs of the DS18B20 sensor call for a accuracy of +/-0.5C. I’m inclined ot think Sensor 2 should be calibrated by adding half a degree F. (We don’t need to be concerned about absolute accuracy as much as the difference in the two temperatures. Differerence of a few degrees should not be a concern either.) (The anomoly at 8:20PM Thurday was caused by me holding Sensor 1 to verify which is which.)
I’m using ThingSpeak which allows eight fields to be sent every fifteen seconds for over a year on a free account. It provides the plot capability which is easy but I’m not real happy with it.
HELP WANTED! If we move forward with this, a web developer who speaks .json could be a big help. Sample input:
https://api.thingspeak.com/channels/343517/feeds.json?results=3
UPCOMING CLASS: @nickWebb and I will be presenting a class in about a month where students will build up a circuit with a Wemos D1 Mini microcontroller and a DS18B20 temperature sensor sending temperatures off into ThingSpeak in the cloud. Same as my other electronics classes: Free, beginners welcome and I furnish everything except a laptop. We will cover everything in the above project and how to send a tweet if the temperature exceeds some specific temperature. You will then be ready to acquire a Wemos D1 Mini, a DS18B20 microcontroller, a resistor and two capacitors to build a module. If you have a phone charger with a micro plug, parts will cost about $10.00.
Paging @Team_Laser
