Following on from Drill Press Help …
I’ve not used the drill press for metals before, so I’m looking for guidance on drilling out some 7/16" holes into a piece of sheet metal no thicker than 1/8” thick.
- I was told to get a Stepped Titanium Drill Bit, and it appears we have one in the drawers by the cordless drills and such. Would this be acceptable?
- Where do we have oil/lubricant that I need to put on the metal to reduce heat?
- What speed should I set the drill press to?
- Anything else I should consider?
I’d like to go do this tonight, in case anyone is available to help. Thanks in advance!
