More details on idea of possible metalshop floor usage that I mentioned in a previous cheaper expansion layout idea thread where there could be a walkway going through the middle of metalshop to connect the two workshops, I think this is compatible with the previous final floorplan layout except that it puts some sheet metal equipment next to blacksmithing in the interim. Something to consider for after we have CO and begin using the new suite.
There would be lots of work to implement this including electrical buildout. I think the dust collection system and requirements in woodshop make it impractical to quickly build a walkway through there, a lot of the metalshop tools can easily be moved individually with minimal or no power requirements or dust concerns (like the slip roller, english wheel, shear, tubing benders)
- Add 250-300 sq ft of floorspace in new workshop, blacksmithing and sheet metal tools (brake, slip roller, shear, english wheel, tubing bender) would all go into this new floorspace
- Creates two welding areas in the back of metalshop
- Material storage, both scrap and committee usage would be along the entire wall but only 2 feet deep, some shallow cantilever material racks could store very long material
- A common 4âx8â work table in the middle, likely with a vice or two mounted on it
- There would be a 10â wide walkway past the end of cnc plasma to make it easy to both load material and service the cnc plasma
- Would have to be additional welding curtains around plasma
