I will be starting with the new LED bulb installs in the metal shop. I may not finish it all tonight, and if not will button up and continue another time.
But during the service tonight the shop may only have some lights running and/or be operating on secondary portable lights.
If you are fine with this then you may use basic things in the shop if you stay clear of the lift, but welding activities are I’ll advised during this time.
Edit: Another session will be starting tonight (May 8, 2019), tentatively at 10pm. This is dependent on the tombstones being present and the correct ones. Since there is apparently a bag of ones procured for these bulbs it seems likely they might be the correct size, versus the ones i found before.
-Jim
