So here are the cliff notes.
We showed the couple new fancy equipment.
Discussed & getting rid of the following:
The old janky drill press, David to find out if another local Makerspace wants.
Harbor Freight metal brake, again to another local Makerspace.
The compressed air tank.
The old shear will be given to jewelry/small metals, providing they want it.
The two current TIG machines are to be repaired then likely sold pending arrival of a new TIG machine. New TIG machine will be offset the cost with the sale of the old machines. Did not go into specifics on make/model but was mentioned that we prefer another water cooled torch. Also we do not see the current TIG machine leaving until we have a replacement.
Modifications:
We will be mounting one of the bench grinders on the wall for Tungsten grinding only. This machine will be locked up to prevent others from grinding just normal steel on it.
Bench for the slip roll will be modified/built, this will be on large good casters.
Classes:
Next weekend I will be teaching the basics for the new equipment. The reason for these classes is to keep people safe & out equipment lasting longer. These classes will not go into detail on any maintenance of the equipment just the do’s & do nots.
Looking for people to teach metal shop 101. The material has been already developed from my understanding.
Looking for others to teach any other classes as well.
New equipment:
As said previously the existing TIG machines are being looked at being replaced. We do want more input from those who use the TIG machine for preferences. Obviously we will be getting a machine that will do HF start AC TIG, likely also liquid cooled torch.
We will be ordering a throatless shear. The Beverly style is the style that will be ordered not likely the brand specific.
Ideas for new equipment discussed but not decided:
Planishing Hammer
English wheel
Shinker/Stretcher.
Personally a tool that would fit almost all the above requests is the Baileigh MH-19. Not likely to happen due to cost, about 25k. It does power hammer, Yoder hammering, bead rolling, English wheel, bead rolling, thumbnail shrinking/stretching & planishing.
I’m sure I’m likely forgetting stuff, so others please input the items I may have missed.
