Metal lathe - help getting started
Hi. My name is Gerard, kind of new to DMS machine shop. I’ve taken BridgePort and Hass classes but now my need is to cut a nipple in a 5/8 inch dia short length axel.
Was wondering if someone might be at the space today or this weekend that might help get me started on the lathe so I can cut these?
Thanks
Gerard
I think you’ll be better served by using a die, it you need standard threads. What pitch are you looking for?
Sorry for the short incomplete description. I will try a post pic later.
There is no thread, just a keyed axel for a sprocket. Need to cut a 1/4 in long nipple down to 3/8 so it slides into socket end to be welded. It will mate the rod to motor.
Turning the round section on the lathe should be easy.
For the key, woodruff, or square stock? I don’t remember seeing any woodruff key cutters, but should be able to cut a key way for square key stock on the Bridgeport with an end mill.
Stock already keyed. Job should be easy but no lathe experience since high school. Don’t want to screw machine up.
Here is a pic of the work
I was thinking of a pipe nipple. This will be pretty simple. I’ll be at DMS all morning tomorrow, though I’ll be busy for most of it. It won’t take long if you just need a quick overview.
Sounds great. I am watching mit videos tonight and reviewing manual so maybe just a short intro will do it. What do you call morning?
Thanks
I’ll be there from 7 til 3 or 4
Job done thanks to startup help from Zau( hope I got that right) and Bryan.
