Hey everyone I wanted to know if there is a way to pause your membership here?
I really want to come back but only when I have time again.
I’m not utilizing the space as much as I did in the summer and being busy teaching school had basically given me no time at the moment to use the space.
You will just need to cancel your membership and then re-join when you have time again. If you use the same email address and user name all your training classes should be there when you sign back up.
There are also no “refunds”; so if you paid on the yearly plan you are active until your year is up [or to the end of your month if you are on the monthly].
The one down side [besides us not being able to hangout with you] is you will be paying whatever the current dues rate is [so if it increases or if you are grandfathered into cheaper rate, you will loose it].
