Measuring an ID
Do we have anything in the machine shop that can measure a bore? The calipers won’t quite reach into the hole and I need a reasonably accurate measurement (+/- .001") I know the diameter is approximately .705 (+/- .005"). I would like to avoid making a set of plugs since the bore is damaged with protrusions
There should be a set of telescoping bore gauges in the red toolbox (courtesy of Walter). One of the unlabeled drawers in the lower section.
