Administrative agenda items
- Discuss Welding Instructor Class (Proposed by @malcolmputer )
- Provide update from Expansion
- Discuss some abusers of the welding bay & better enforcement of payments (MIG statues and the like)
- discuss any new business & requests
- Look at Lincoln TIG hose and see if we want to replace it
- Discuss new inverter TIG machine (@yashsedai)
- Vote on Chair
Must Do Chores List
- Check our current assortment of safety glasses (both shaded and clear)
- Remove the Red Tool Chest, and some of their less often used totes to the new blacksmithing area. Recommended by Expansion to grab some pallets to make them easier to deal with. Why are we doing this rather than them? So we can get some of our space sooner.
- Clean up remaining metal items on black shelves and disassemble and/or move
- evaluate adjusting the committee steel storage with black shelves out of the way
- Weld new Large Oven base using the I-Beams @procterc procured
- clean up committee roll up since it’s overstuffed again
** Weld small cage for pony bottles to get them out of committee storage. Will CAD in advance - clean up tall cabinet on welding bay. Stuff in it can more likely be tidy’d up across the back row of shelves. It’s never closed anyway.
- make Vinyl / Other labels for the front tool chest “KEEP CLOSED” (large, inside lift lid), “Batteries” (outside lid , smaller), “Material Removal” (for material removal drawer with files etc), “Screwdrivers / Pliers”, “Hammers and Punches,” “Power Outlets” (on lid)
- check grinder wheels
- check welder wire and gas
- Anchor the Drill Press somewhere (it’s not on stable enough of a base)
Other items for todo list
- weld oven jig (come on, it’s been months)
- inspect large belt sander Dust Collector (was cleaned last meeting, need to see what else is required or if it’s just working. Will encourage heavier use if functional)
- Look at better bending die storage. New 1-3/4 die has a shipping notice.
- laminate the new vapor hone instructions (which had been finished in layout after the last meeting)
- find some way to lock the pressure regulator on the vapor hone due to repeated abuse
Items for Acquisition on Supply Runs
- Vapor Hone media, if needed (Aluminium Oxide, by the Bucket)
- Steel Paint Pens (at least 3x orange pens, other colours possible but not a priority)
- 2x 1 gallon containers of Acetone (one will be marked & reserved for committee / teaching use)
- basic drill bit set for the drill press
