Making Foam Inserts | Cumbest 6.6.24
Not sure what category this would fit in, but I’m trying to make tall foam inserts for a belt pouch. Does anyone have experience with foam inserts? Where do you get your foam from? Do you cut it by hand or using the laser? I was considering making .5 in sections and gluing the stack together to make it tall. Any advice is greatly appreciated!
I haven’t done a lot of foam inserts, but if it’s just something that needs to bulk a pouch up, you can probably get away with cutting it by hand using an old steak knife or something. Probably be faster and easier. But if you need something super precise, the laser is going to be the way to go.
