I need to make a funnel out of Brass or some other material that doesn’t spark. I’m planning to do this on the Sherline lathe since it’s small, but I haven’t done much with brass before.
Any notes on types of brass or working it I should be aware of? I heard something about it hardening as its being worked, but have no indication as to why that would happen with any level of significance without torching it. I’ve done aluminum and steel but never had a need to work with brass before.
The other concern is if we have a cutting head available for the sherline that can make the inside mouth of the funnel. Not trying to make a super smooth curve or anything like that, but it would be a slanted profile after some flat inside walls.
