Do I put my truck on the lift to see what was making a rattling sound. Lo and behold, a bolt was missing from the skid guard.
I hate getting bolts for my truck. Why? For whatever reason Fastenal and the other usual supplies don’t keep it stocked. The bolt is a M10x1.25mm, and most places don’t seem to stock M10 with less than a 1.5 pitch. So normally, for an accessory I would just order the bolt and wait. Unfortunately, this skid guard uses the bolts for some more sensitive parts involving frame mounts, and missing that bolt is a no-no.
So what to do? I decided I’d get help turning down a bolt on the colchester and re-threading it. The problem? The die set in the machine shop is imperial. The metric die set in the workshop is harbor frieght carbon steel. It wouldn’t thread any decent bolt steel.
So options? I had some more brass round stock, and decided screw it, I’m making a brass bolt on the Sherline lathe and Bridgeport because my truck has started to hate me and I’ve been on a lathe binge recently. I figured the Brass would hold long enough at the least for a new bolt to arrive. In the end, it turned out to be harder after the heating it took and I’m gonna see how many miles / ranch trips it survives.
The short of the process:
- turn down round stock to length and width of the threads on bolt, leaving the head fat for making the bolthead
- use the bridgeport for the bolt hex head. This was fun without the DRO since it’s currently non-functional (opening a ticket on that parallel to this)
- leave some of the round stock to act as an integral washer since I don’t have the original washer either.
- Realize that I forgot to chamfer the end of the bolt on the lathe so it threads cleanly; proceed to have the lathe throw the part as you go back with a now more difficult to chuck part
- decide the accidental knurling looks cool anyway, and thread the bolt.
- install on car and laugh at this stupid thing I made, laughing even more when it’s successfully torqued using the socket set since I bothered to make a proper hex head for it.
People who may or may not have laughed at the misfortune of how the bolt went missing, solution, and/or asked me to post on talk: @TLAR @Kriskat30
Pics or it didn’t happen:
BrassBolt Begins
so we’re really doing this? godz help us
Oh gods why am I eyeballing this wait for the DRO to work again
huh worked better than expected for an eyeball
stupid chamfer setting me back and making my otherwise pretty part look bad
not bad once you get past the shavings and the surprise knurling
holy crap the socket works on it and it torques surprisingly well
