I was up last evening turning thick boards into thin boards, and the whole time I was doing my thing for me, @themitch22 and @Brian were working to bring the MultiCAM into better working order. (edit: I believe @tapper may have had a hand in there too)
Phrases overheard included something along the lines of “it’s still off by 5-thousandths.” Shims made of energy drink cans and aluminum foil were involved.
Thanks, guys, for doing what you do!
(If others were involved before or after I left or when I wasn’t paying attention, I meant no slight by not mentioning you by name!)
Mitch is now our Multicam man!! By the way, Machine shop has shim stock, but the if you really want to hacker it with aluminum cans, go with diet cans, no sticky sugar residue.
It was installed on the Machine shop computer when that existed way back when. That didn’t work out for us and we decided to switch to Vcarve because training is easier, more information exists on the web and there are already tutorials. Another reason we moved away from it was because it required a dongle to work. We should still have the disc and dongle in the server room but I haven’t looked/seen it in years.
Why do you ask? Is there something that cant be done in Vcarve that you need Enroute for?
I was just wondering because I know MultiCAM pushes for it but there’s a ton of CAM programs, especially Fusion 360’s CAM which I have not tried yet. I have a copy of Enroute and was wondering if training on Enroute would be worth it at the space.
For shim applications with shear load, the plastic coating on most aluminum cans can act as a lubricant, and cause the shear load to be transferred to only areas without shims, or the fasteners. Maybe not an issue here, but something to think about next time you reach for a can when other sources of uncoated shim stock are available.
