So I figured I would put a To Do List for things in the Machine Shop on Talk.
Bridgeport
- Install new strain relief on the Powerfeed input power.
- Seal Powerfeed motor gear box & add gear oil (90 weight). Done 8-4-18 by @mikeglass, Thank you Mike.
- Assemble the Metric Collet holder, well done by @mikeglass on 8-6-18. Thank you again. & find a spot to mount.
- Build/Print/Buy T-slot cleaner for Vacuum to better clean the T-slots
Colchester
- Create tool holders for the lathe tooling & Chucks
Shark Lathe
- Mount & wire replacement Power switches & Pilot lights
- Create a Chip Backer to contain the scarf/chips from chuck
- Mount 5C collet chuck on the backing plate
Evolution Saw
- Create a backingplate to catch the chips.
- Tarp/Cover over the cart under the saw. Potentially with Plexiglass or other material.
Sherline mill (Metric)
- Mount to a baseplate. Done by @mikeglass on 8-6-18, Thanks Mike.
CNC Sherline
- Order the required parts
- Assemble the new Stepper, Motion controller & power supply, Then test.
Surface Grinder
- Unmount the coupling half from the arbor & look at the bearings
- Buy & replay the “Joy” coupling & re-assemble the grinder arbor onto the machine
- Buy & mount Magnetic chuck
- Replace the Way’s oil line
- Create a cover plate guard to cover the front of grinding wheel to housing.
- Create a guard to catch the grinding debris
Misc
- Mount Cameron Drill press onto bate plate.
- Look at what it would take to add hour meters.
That’s all I can think of at this moment, I know there it more. I will add to the list on this post as needed to modify it.
