There are 17 roof trusses across the entire warehouse, going North to South. I figure each supporting span of the cable tray would require 2 each 10 ft long 5/8 inch all-thread fastened to the ceiling trusses with special C-clamps that attach to the trusses 20 feet above. The C-clamps are threaded to allow the all-thread to be threaded into. The bottom of the all-thread will have a 24 inch piece of uni-strut bolted at the end. The cable trays will be supported by the 24 inch long uni-struct cross member. Repeat this process for as many trusses as required. The only machining required is to cut the uni-struct into 24 inch long pieces and to drill 2 each 5/8" clearance holes for the all-thread. We have access to a one man power lift to attach the C-Clamps and to lift the heavy cable trays into place. A couple of tall ladders can be used as needed.
One may ask why we are using 5/8 inch all-thread when 3/8 inch would probably do. The special C-Clamps cost about $18 to $20 a piece. I picked up 100 brand new 5/8 inch special C-Clamps at an auction for 9 cents a piece. . . that’s why. The up charge for the larger all-thread was minimal considering the cost savings we got with the C-Clamps. Just trying to save DMS some Expansion funds.
