@Team_Woodshop I just reactivated my membership now that I finally have some time off work and wanted to confirm I would have access to the machines in the woodshop with my reconnected badge. Does anyone know if there is a way to check what you have access to tied to your key fob?
Swipe your badge on the reader in the common room at the end of the long table with computers. It will tell you to what you still have access.
You can see your groups in MM4 (lower-right corner)
https://makermanager.dallasmakerspace.org/
Just don’t try to use it for badge management or anything else really. It’s only partially working right now (use the link for the maker manager at the top here for everything else)
The test kiosk for badges in the common room will also list your groups when you scan your badge.
