Low fire glaze request?
Hi! I am wondering if it is at all possible to schedule a low fire glaze load? Who do I talk to about making this happen?
Sounds like the realm of @Team_CeramicsFire
What specifically do you mean by ‘low fire’? If you are looking for around 04, then that is what the regular bisque firings are done at and you can place glazed pieces in without problem. I’d advise a small note that indicates what they are so folks don’t wonder if you have the right shelf.
If you are looking for something other than 04, then that’s the realm of special firings and you would need to discuss details with @brendamvilla or @Monikat.
Edit: Unless you mean an entire kiln load of your own which is also doable (scheduling is dependent on community firing needs), just contact the above. :slight_smile:
Thank you!
