Hello,
I am trying to cut out a shape on the Thunder. I made up an image for it which is being saved as a PDF. the Image has each of the cuts I want to make in a different color channel. NimitzColored8in_2.pdf (121.1 KB)
When I load this file into Lightburn, the color is lost, and the cuts are marked as “Image” instead of “Line”
I thought this was the same procedure I followed using a previous project which did work. A picture is below. Notice how each color shows up as a separate cut, and you can select to cut a line or to fill.
My only guess is this might be due to raster vs. vector graphics. I made the current project with GIMP which is rastered, and the previous project was made in inkscape and I believe it is vectored.
If you have any idea on how to get this project to load correctly in the Thunder, please let me know!!
