I’m currently getting ready to redo the electrical in my truck. I took out the few hundred Ah worth of AGM batteries a few months ago, and now want to get the lithium replacements going.
I am looking for the best way to handle the charging / discharging of the system. I would like to be able to have a charger that operates off the alternator when the vehicle is running, and off 120/208 when parked.
I’m not as familiar with lithium systems, but I figure I could collect the knowledge from here. I have asked around before and gotten a few leads but was terrible at taking notes
Most of the onboard chargers I’ve found operate in the 24v low end, which would mean adding some very beefy buck converters to the output for the 12v vehicle system, although it would allow for a 24v inverter rather than my current 12 (more efficient).
I currently have 8x large batteries (was planning to run 4s2p to replace the 12v AGMs, since most equipment will operate up to 14.2v), but can also run 8s if I go with 24v equipment)
I’ve built SLA/AGM charging equipment before and typical regulator systems, but I’m not familiar with lithium charge curves and making buck converters that beefy.
Cheers,
-Jim
