I had to do the same thing when I flew southwest in Feb. I know cargo will not allow them either. Saw a pretty in depth airline/FAA/NTSB video on it not to long ago.
Awesome. I definitely would like to use a safer charger so this doesn’t happen again. I would also like to maybe write up a quick user guide so novice users like myself don’t burn down the makerspace because I don’t know how to properly set the current.
Does the old charger still work?
Yes, but the buttons on the right side are melted so it’s hard to press the button or see the LCD.
What’s the plan for it? Trash? Disassemble / reverse engineer? Use as-is?
It’s still useable, and the LCD screen appears to still work correctly.
A post was split to a new topic: I need a course in setting up a new profile and buying the right receiver for my DX8
I was talking to @hasbridge about the training discussion going on in this thread. Below is a link to a power point i made years ago, for fire fighting training classes I conducted at Love Field. It’s a broad strokes, quick presentation, designed for people who have no experience in fighting fires. Feel free to hack it up and make it into your own.
https://drive.google.com/file/d/0B-Xq4FPUT9N2emVrTmhUQ0UyQ28/view?usp=sharing
Kent
So I see we have received our new charger, but it requires a DC power supply. Any chance we have one or can get one to set it up?
Also anyone familiar with this charger want to show us how to use it?
Yes @themitch22, I have a HP server power supply that I will donate to the Aero/RC Committee to use with that new Venom charger. I will bring the power supply with me tomorrow evening when we have our Committee Chair Discussion Meeting at 9 PM.
I am here at the Space and I just happen to carry around a spare power supply with me at all times… but it seems this one just meets the minimum 300W, whereas yours probably hits the recommended 500W.
I left it on the shelf (donation) incase someone wants to make use of it…
I am not so sure about enclosing batteries that can overheat in anything that is not well ventilated. If one is to make this kind of battery bunker, they should probably find a way to assure a lot of ventilation (maybe fan table under it?) or other cooling take place while charging. If even a small fraction of batteries overheat due to being enclosed that would not be good.
How about using the cinder blocks more or less as shown with a fan table under them. Design a system using smoke detectors that shuts the fans and drops the sand? Possibly the concrete block might be permeable enough to sandbag the top and still have enough air to cool the batteries while charging? Another possible method might be to use a water chamber to charge the batteries. This would give exceptional heat transfer, the batteries are well sealed I am sure. OR possibly wet the concrete blocks before using them with the fan to gain evaporative cooling? There are plenty of possibilities to improve the safety even further.
@Dirk_Jeanis much has transpired since the earlier posts. There is a brand new, in the box charger with enclosed metal cabinet that was purchased. Link and photo above.
Maybe we’re overcomplicating this?
I suspect direct contact with concrete is going to be far more effective at transferring heat away from the batteries than circulated air.
In any case, as @AbelRamirez mentioned, it makes no difference. The idea for a battery bunker does not have momentum.
Nope.
The thermal conductivity of concrete varies from 0.1 - 1.8 W/(m K) , while the thermal conductivity of moving air starts at about 10 W/(m K)… and goes up depending upon how fast the air is moving.
Moving substance almost always has greater heat transfer since part of the equation on the speed is the difference in temperature. When two items are in permanent contact the transfer of heat slows down as the difference in temperature decreases. With a moving liquid/gas you can nearly maintain a constant differential in temperature.
I am pretty sure LiPo batteries in good working condition do not get ‘HOT’ when charging. They only get to 100+°F when there is something wrong. Usually just before they burst into smoke and/or flame.
And not only does this Venom Stronghold charger monitor the battery’s temperature while it’s charging, but it also monitors the battery’s internal resistance of each cell. When a LiPo cell’s internal resistance starts to increase, that is the #1 indicator that something is going wrong with the battery.
