After taking off the second nozzle donated printer is working like a champ… or rather as champy as he’s capable. The issue was definitely the second nozzle running into the prints so how does one level nozzles or do we just run it as a single from here on out?
One of the biggest problems with a dual extruder!!! All the hot ends that I have used the top of the heat sink would screw into the top mounting block, and the heat block would screw onto the heat sink. When you screw on the nozzle it tightens against the heat sink, therefor adjusting the heat sink height at the top would in turn adjust the nozzle height! Maybe a picture of your extruder setup would help.
Just the tips or the whole thing?
