Mine is a 2005. The chain itself doesn’t seem to be the problem, it’s the tensioners/guides that wear out and fall apart. It’s not just Fords, lots cars have the problem. So “it’s not the timing chains going bad” it just all the structure that supports
[) Ford Triton 5.4L Timing Chain Issues Alright – there are a few things to discuss here. We’re simply referring to these problems as timing or timing chain related. The timing chain itself can be an issue on the 5.4L engine. However, timing chain tensioners and variable valve timing (VVT) are known trouble areas too. The 2-valve 5.4 Triton does not have VVT, so that’s isolated to the 3-valve Triton.
We’ll avoid getting too technical for now. Long story short – timing is a critical part of proper engine operation. If these issues aren’t resolved in a timely manner further damage can occur. Usually 5.4 Triton timing problems arise from a loose timing chain. The chain then slaps around a little bit, and given enough time that’s all it takes to break the timing tensioner. Some 5.4’s also run into issues with the VVT and that’s primarily due to the cam phaser breaking.
When a timing chain or tensioner fails it’s possible to throw timing off pretty far. Ultimately, that may lead to the 5.4L Triton valves contacting pistons. That’s an engine out failure at the least, and may even destroy the engine beyond repair. It’s not extremely common for this to occur, so we don’t mean to scare anyone. However, it is possible which is why these are important problems to look out for.](The 4 Most Common Ford 5.4L Triton V8 Engine Problems - 5.4 Reliability)
