Ive been playing with my thunderlaser at home and have been testing cutting glass with it.
with pretty good results!
cuts were made with 30speed 30 power on a 120w thunder laser. passes need to be duplicated and have the path direction reversed, then run 8-10x times to make sure a thermal crack gets put all the way through.
both of these were cut (cracked in a precise area) and the pulled apart with just fingers and maybe a bit of tapping with the back of the cutter.
perfect on the first big curve. popped right off.
got too greedy and tapped too hard, cracked the main piece.
initial tests
