@cvrana The material I was using was 10mm thick EVA foam, and I had confirmed it to be safe to use on wiki.
Here is the amazon link to it: Amazon.com
I still have it kept there.
I was cutting it at 90% power and around 13 mm/sec speed.
It was cutting perfectly fine for about 45 - 50 mins:
I’ve cut multiple sheets like these, and some smaller ones for testing too.
After about 45-50 mins, it started a minor at which point I realized that the air nozzle is not working.
I definitely should have checked the air nozzle beforehand, which was a major mistake from my side. I will check it for all my projects next time onwards.
Could you please confirm if the material is safe to use in laser cutter again and if yes, what should the speed/power settings be to not put it on fire again?
