The laser seems to not be cutting well.
I cut some 1/4" (5.2mm) Baltic birch plywood on the laser last night, using the same settings (and same wood) I used the week before (65 speed/100 power/ 1 pass). Failed to cut completely through. Did two more passes at 90/100 and then 70/100 and STILL failed to completely cut through.
I did all the usual setups (set Z-height, verified current, used flat wood).
Seems that perhaps the optics are either fouled or out of alignment. Perhaps someone more qualified could check it out?
In addition to this email, I updated the DMS ToolStatus Page: Tools Status Board - DMS
